need to order fuel rail fittings asap! please help
Old 07-19-2011, 09:38 PM
70c10's Avatar
Default need to order fuel rail fittings asap! please help
IM running speed inc hi flow rails 60# injectors corvette filter reg set up master power t70 turbo and a single intank 255 walbro. What size fuel line should I use for the feed from the reg to rail and reg back to the tank. also need the crossover size. I plan on running no more then 550 whp. would -6 be ok for everything. Thanks
Old 07-20-2011, 10:14 AM
70c10's Avatar
Ttt bump
Old 07-20-2011, 12:12 PM
FlamingTA's Avatar
I'm not an expert at this but I would guess that you should run -8AN from the back to the front. Use the 3/8 feed line as your return line. Cross over could be either -8 or -6, -6 should be good tho.
