LS2 intake
LS2 intake
Will an LS2 intake fit my 98 TA LS1?
It appears to be from a 6.0 2006 Monaro.
I am in the UK and second hand LS1 stuff is thin on the ground here.
There is an ad on ebay.uk for a LS2 intake is this the same as an LS6 intake or is it a totally different altogether. Here is the ad:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
The same guy does have a 90mm TB for sale alao.
If it there is no way to use my TB it maybe a non starter.
I did a search on swapping an LS2 intake on to an LS1 and it will fit if you use a fast 90 TB.
But this would make it expensive as a swap for me and I would be better off with a ported stock TB and then an LS6 intake.
Adapter plate
I have been doing more reaseach on this. I have a stock ported LS1 TB on it's way to me. I maybe able to make this work if I can get a 4 bolt to 3 bolt adapter and a throttle cable bracket.
Where can I get these and how much are they?
