Walbro 255 pump/what psi is it?
Just put a walbro 255 pump, #gca758-2 from summit, in my 6.0liter chevelle, and it's only puttin out 28-30 psi at idle. I changed the fuel reg. on the rail and is the same (trk intake). Checked for kinked lines, fuel filter. all ok. The description for the pump is it's for a 85-92 350ci camaro w/tpi. Is that OK.. My tuner says it needs about 55psi.
The pump had 3 lines off it, one fuel, the other one to return, one to vent.....hmmmmmmm maybe I put the return to the vent one? Any ideas????
Thanks Rick
Thanks Rick
regulator sets the pressure not the pump so pump should be ok. 255 pumps seem to only differ in arrangement of the bottom pickup to fit different buckets. some are offset some are centered.. other then that any 255 pump should all flow 255lph.
im wondering if that "vent" is a venturi setup?
