What fuel system?
Old 09-04-2011, 11:15 PM
1C3 MAN's Avatar
Default What fuel system?
Hey guys im about to swap a Gen 1 SBC into my 95 camaro and need some help with the fuel system.
I read that the stock ecm wont work. So i need to find an aftermarket fuel management system. But the kicker is i need one that will run the gauges. Because i know the stock opti runs the tach and it wont be on this motor.
Any information would be very appreciated.
P.S.
The motor will be making around 500hp if that matters
Old 09-05-2011, 11:50 PM
1C3 MAN's Avatar
So I'v been reading about ALOT of systems. And i really like the looks of the FAST EZ-EFI system. but the only problem i see with it is that it's not
recommended to run nitrous with it.
Anyone ever run a 150 shot with the fast kit?
I read somewhere that if you change the wot air fuel ratio you can run nitrous and just change it back when off the notrous.
Also with this kit do you keep you stock ecm to control the gauges?
