Fuel system for my LQ4/TC76 setup
Old 09-29-2011, 08:04 PM
DavidPHumes's Avatar
Default Fuel system for my LQ4/TC76 setup
(not posting this in the fuel subforum because there's not a lot of FI going on in there)
Hey guys, here's the relevant setup information you might need:
Motor:
2003 LQ4 (6.0L, 365ci)
ARP 2000 rod bolts
ARP Pro Series head studs
GM Performance MLS head gaskets
Virginia Speed 232/226 .588/.574 115LSA
Comp Cams 26918 valve springs
Comp Cams 7.400" Hi-Tech pushrods
LS2 timing chain
Melling "296" high flow oil pump with high pressure spring
LS7 Lifters
LS6 Intake manifold
Ported stock throttle body
Fuel System:
Hinson Super Cars LSX Racing Fuel System (-6 feed, -6 return)
Corvette fuel pressure regulator
Siemens Deka 80lb fuel injectors
Turbo setup:
Turbonetics TC76 (.96 A/R, F1 turbine wheel)
Turbosmart 48mm Pro Gate external wastegate
Turbosmart 52mm Race Port BOV
SSAutoChrome 24x12x13 Bar and Plate FMIC
I'm going to be running ~10lbs on 91 octane fuel. Target RWHP is 600. The car is an RX-7 which currently has an in-tank 255lph Walbro. Would I be wise to put in another Walbro or should I get a Bosch 044 and put that in line after the Walbro? Looks like the Walbro -> Bosch 044 setup should be good for around 750RWHP... but I'm not too sure about that. The last thing I want is to lean it out...
Old 09-29-2011, 08:46 PM
Coal Mining Director
onfire's Avatar
The target of 600 will go up....it always does...lol...so add another Walbro beside of (not inline with) and turn it on with a Hobbs switch, pcm, etc. Be sure to wire it totally separate from the first Walbro...the 80lb injectors will max out before twin walbros.
Old 09-29-2011, 08:58 PM
madmax4499's Avatar
i agree with onfire, hell you can hose clamp two pumps side by side if the car dosent have a bucket.
you will max out the turbo and injectors before you need more fuel.
it will be super fast at 600 hp. have fun and keep us posted.
Old 10-04-2011, 11:20 AM
bonestock_442's Avatar
Twin pumps would be the best setup because you will be turning it up. I have a similar setup, but run e85 and find myself pushing 15 psi at times.
Old 10-05-2011, 08:05 AM
Old Geezer's Avatar
I'd be considering a change to the fpr/filter system. @ those RW numbers, an adjustable, boost reference regulator would be my choice.
Old 10-05-2011, 04:47 PM
deatschwerks's Avatar
...or you could use a DW301 in parallel with your W255.
http://www.deatschwerks.com/300-lph-fuel-pump
Run off the DW301 since it has the flow you need and is a quiet pump, should be able to at your current goal, and if more flow is needed later on down the road...give the DW301 a little more voltage or power the W255 with a hobbs switch.
Old 10-05-2011, 08:01 PM
madmax4499's Avatar
cool pump, do you make them in the inline format?
Old 10-06-2011, 09:14 AM
We don't have an inline available at this time.
Old 02-04-2012, 09:12 PM
FAST LS1's Avatar
Would two of these pumps be enough to support 1000hp running E85?
Quick Reply: Fuel system for my LQ4/TC76 setup
