2nd fuel pump, need switch for stock pump
I've been searching and cant find what wire gives the stock pump power. I have a 98 with a hotwire kit. I've wired up everything except for the switched source. I don't have a hobbs switch, I want them both on at the same time. So I need to know which wire is switched. I seen something about a green wire, but it doesn't say which one.
Thanks for the help
Thanks for the help
Maybe this is it. I found the pinout and it says for the 98 it's the blue 37 for the fuel pump relay. I would just think that there would be something closer to the rear to wire it.
http://www.ls2.com/boggs/torques/98pinpcm.htm
