aeromotive 340 in tank pump
Old 10-05-2011, 09:25 PM
th3m0nk3y's Avatar
Default aeromotive 340 in tank pump
Would anyone know if aeromotive 340 in tank pump work on a 2005 GTO or what needs to be done to install one of these in the stock location....
Old 10-06-2011, 08:01 AM
bravolistick's Avatar
1. Yes it works in the tank.
2. You will need a Teflon spacer and a injector 0-ring.
3. Find a spacer that fits over the pump nipple but doesn't cover the tip so you can still fit a o-ring on it. If you want to you can get the directions for the LPE kit online and use them as a guide.
4. Depending on your power level, you may or may not need to drill holes in the bottom sides of the bucket. The 340 pumps flow quite a bit, and you run the risk of sucking the bucket dry if you’re going WOT on a low tank.
Old 04-24-2012, 10:01 PM
Pillion88's Avatar
Not to thread jack but bravolistick are you running a single intank 340 on your power level?
Quick Reply: aeromotive 340 in tank pump
