How much rwhp on 98 camaro injectors?
It would be a great idea.
I just did heads/cam and mine are at 104% duty cycle by 5200rpm. They were hitting 92-94% at 6500rpm when I was cam only with a smaller cam.
You don't want to run them over 80% if you want them to last. I've heard anything over 92% costs you HP.
I would look for some 38-42# injectors. Do not put them in until the car is at the shop to be tuned or you will wash the cyl walls with fuel and risk damage.
FWIW, I wouldn't go over a 36lb injector, IMO, if you're running a N/A motor.
I Suggest these for you.
http://www.corvetteinjectors.com/sho...?productid=322
And like thunderstruck507 said, don't replace them until you get to the tuner!
