In tank fuel pump position
Do factory in tank fuel pumps need to be mounted to where they are standing about vertical, or can you angle the fuel pump in a different manner? For example, tilting it a bit or even mounting it almost horizontally but flush against the floor of the gas tank.
Additional information: I'm running a factory style fuselage, and this isn't for EFI. I'm running a carbed LT1 and I bought a 3rd gen TBI in tank fuel pump that I'm gonna rig up to the factory style sending unit and place it in a baffle. Figured it'd be a clean, factory style setup and the TBI fuel pump can be regulated down to around 5-7 psi.
Thanks, Josh.
Thanks, Josh.
