Installing fuel pump, what it takes to disconnect fuel lines?
On my 98' TransAm things are quite rusty and dirty and having only quick look I wasn't sure what do I need to disconnect 4 lines. Any special tools needed? Or just plyers? Are all 4 lines disconnected in the same way?
I was thinking of starting a thread like this, but I was more/less wondering about other things to watch out for that might break or get in the way. But I thought I'd just drop the tank and figure it out. Can't break anything back there THAT expensive anyway..
But OP, the lines should be easy to disconnect.
There is a fuel line disconnect tool. It is a small round tool that clamps around the fuel line and slides into the fitting opening up a spring clamp allowing you to pull the line apart. Do not just pull on it you will break it. The tool is cheap at autozone or oriley's. I think you will need two different sizes a 5/16 and a 3/8 one for the supply and one for the return. I think the 5 piece kit is only 5 dollars or so.
