1000hp fuel system question
Im looking at making a 1000hp fuel system for my camaro and was wondering what would be a rough estimate for the cost. And if anyone has done one could you post up the list of everything you used?
i have a dual areomotive setup 2000hp setup that runs awsome look into that and is it for efi or carb
i have
two aeromotive a1000
one aeromotive pro seriers regulator
10an feed and return
10an check valve
12an pick up from the tank to pumps
boost switch for second pump to turn on.
modified fuel rail
i think i have 2k into the fuel system (ball park)
i have all my old lines and fitting with a Aeromotive 13101 regulator that will hold 1000 crank horse
i have
10an check valve
modified fuel rail
I've got about 2k in my fuel setup.
Sumped stock tank
Magnafuel 4303
-12 filter feeding the Magnafuel (Magnafuel filter)
-10 out of the Magnafuel w/ Russel filter
-10 to the front
Pro Products rails
-8 out of rails to A1000 regulator
-8 back to the tank
Trick Flow 120# injectors
We just made 911 RWHP (with plenty of fuel left) on a clone of my fuel setup (as in, exact clone) on my buddy's car, on E85.
Sumped stock tank
Magnafuel 4303
-10 to the front
Pro Products rails
-8 back to the tank
The following 2 users liked this post by digitalsolo:
camsthechamp (06-04-2023), enigmah (10-29-2019)
i have a aeromotive regulator 13101 for $75 and 6an lines. pm if you want to buy them i will mesure the braided lines and i will make a list of every fitting and thenth of lines. but tell me what fitting you want straite, 45, 90, 180 dregree. and ill charge you half price for every fitting if you want i have alot of them so please tell me what ones you want. i had them in a 94 z with the pickup on stock tank feed spots on the top of the tank.
