Teflon hose
Teflon hose
ordered the summit brand 6an teflon braided hose and it came it today and looks to be the same size as my 4AN turbo feed line.. problem is my fuel line is 6an and the new teflon braided line looks way too small. called summit racing and they said that the line i had was 6an. so what teflon hose do i need thats the same size as my old 6an hose? OH and the rep i talked to said that i was mistaken that the regular braided lines were weaping fuel and thats what is causing my 3 year old lines to smell.... said there were other problems...right....
i can tell you this that Teflon braided line looks smaller visually but the inner diameter compared from the inner rubber hose and Teflon is very close plus/minus or the same i can tell you this because i ran my complete fuel system Teflon here is a pic of -8an Teflon and yes this is #8
Teflon is great no fuel smell on my cobra rubber braided omg would make the whole garage smell like gas from seepage here is the site i used for my braided line they are out of Colorado,USA!!! im not sure if summits line is any different but all it uses is a compression fitting instead of traditional rubber braided has the threaded nipple that you shove down the line lol hope this helps pm me if you got other questions
http://www.anfittingsdirect.com/stpg...id=ptfe_teflon
Kleeborp the Moderator™
http://www.lonniesperformance.com/
I will warn you now...it won't be cheap. The hose ends are very expensive, especially if you need anything other than straight ones.
Call Lonnie's Performance (he's a sponsor on here) - he carries Goodridge lines and fittings.
