1st gen ls6 swap fuel issue. please help?
68 camaro gm crate ls6 with 4l60 98 f body fuel rail corvette reg for return to tank with 255 pump. car ran fine started right up ever time with just a click of the key,now it just cranks and cranks if i prime fuel pump few times it will somtime start also if i keep trigering key like never let it get to the 3 sec prime shut off it fires up checked pressure at schrader valve only 15psi .so i changed pump still dont want to start and friend took his gauge back . i am tring to think of everthing i have switched sine this started? only things that come to mind is lokar throttal cable didnt have one at all before. moved ecm to difrent place and went to a permanent power sorce for ecm. with old pump i might have ran it empty. new pump since. thanks for your help kevin . going to slowhawk sat
