Edelbrock vic jr intake and rails. what injectors?
I have ls3 injectors and they are to short.i was thinking maybe a spacer would do the trick but is a spacer really a good idea? Or should I buy the proper set of injectors? Btw I need 42lbs
you want to stay away from the svo 39lb blues, cause the have a split spray pattern designed for a multi valve head.
http://www.corvetteinjectors.com/sho...?productid=354
http://www.corvetteinjectors.com/sho...?productid=371
top hats will work fine.we also have a set of 42lb full length with uscar plug.
