Fuel regulator
Old 12-02-2011, 07:30 AM
1994 interceptor's Avatar
Default Fuel regulator
Can any one tell me where the fuel regulator is located at???
And if there is any way to check if it is bad
Old 12-02-2011, 08:52 AM
Ollie8974's Avatar
What year,model. Some years and models it is mounted on the fuel rail and some are mounted in the fuel pump module.
This is a 99-2002 Firebird/Camaro fuel pimp module showing the pressure regulator.
To check operation, connect a fuel pressure gauge. Pressurize the fuel system and time how fast the pressure builds up.
Turn the key off and the pressure should hold for quite a long time.
Whit this test the pump could be faulty too.
Old 12-02-2011, 02:28 PM
It's a 94 lt1
Camaro
Old 12-08-2011, 07:34 PM
men7707's Avatar
Hello, I am having a problem with my 02 trans am. It has an extended start I checked the fuel pressure with the key on, car off and it shoots up to 58psi then a second later it drops and that's when the extended start begins. I also checked the fuel pressure with the car on idle and it's a steady 58psi and even when i accelerate it stays a steady 58psi. So, I'm leaning more towards the fuel pressure regulator being bad. Any feedback would be appreciated
