Help me build my fuel system :)
I am doing a turbo build this winter and just want advice on which fuel components will be adequate for my goals. I am looking to run around 550-600whp as this will just be a street car and a summer cruiser.
I am planning to run pump gas since we do not have e85 available in my area unfortunately so 60# injectors should do right?
On the fuel pump side of things is really where I need advice. I actually have a walbro 255 in-line pump that is new that I never used on another project. Can I run the stock in tank fuel pump and plumb the in-line 255 in and run it all off a racetronix hotwire kit and be good or will this not be enough fuel?
Any advice is greatly appreciated!
LS1TECH Sponsor
1. The fuel pressure regulator is on the fuel module in the tank / it is not a full return system.
2. The jet pump must be run at 58PSI so adding a series pump is not an option even with a converted front-mount regulator system.
3. The factory pump will not keep up with a Walbro GSL392.
You may consider our system here:
F99 Fuel Pump Kit
RFPK-001 - 1999-2002 LS1 Camaro / Firebird / Trans AM
If you require more fuel you can add a PBIC to your kit and purchase a pump booster.
Alternatively you may consider a Lonnie's/Racetronix dual in-tank system:
http://www.lonniesperformance.com/
60# injectors should be plenty for your quoted HP expectations.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
Thank you for the response and info. I have run Racetronix components in the past on other projects and have always been very pleased so I will likely go with the kit you suggested. Should this single pump be adequate fuel for my goals? Or should I possibly look into the Walbro 340lph in tank pump?
Thanks again!
Thanks again!
LS1TECH Sponsor
At 550-600rwph you are in dangerous territory with a single pump.
Many of the larger single pumps will not allow proper idle fuel pressures without fuel system modifications.
The dual pump kit will support approx 700rwhp on stock lines & regulator and roughly 1000 with a modified fuel system. This will easily & safely support your current power needs & also well into the future when you start adding more modifications.
Feel free to give me a call if you are interested in a dual pump system.
I will get you the proper components wthout buying things twice.
