99-03 vette fuel filter
Old 12-15-2011, 12:30 PM
Wire guy's Avatar
Default 99-03 vette fuel filter
Has anyone used this fuel filter as the fuel pressure regulator? I have heard that it keep the fuel pressure around 58 psi and return the rest to the tank. I want to run two 150 liter per hour external pumps in front of it and #8 out of the regulator to the ls6 fuel rail I have. The motor is a rebuilt lq4 that is balanced and has a z06 cam. I will be adding a turbo and bigger injectors later.
Old 12-15-2011, 11:56 PM
01ssreda4's Avatar
Lots of the LT1>LS1 swap guys use it.
