SVO vs. FRPP "39LB" Injectors
Hello everyone. I have tried to research on this subject but haven't found a whole lot, I think because the search criteria is so broad. I have found a plethora of threads that suggest SVO injectors (30LB) but are supposedly around 35-36LB at our pressure. However as I was shopping around I have found the Ford Racing 39LB injectors, according to the literature on WS6store they should be around a 45LB injector at our pressure. My question is what would be a better choice for me? I have found a few threads comparing 36 to 42 lb injectors and most suggest going with the latter.
Current set up is a 00 Z28 with LT's, ORY, catback, Torquer V2, LS6 intake. I am planning to go with a set of heads after the winter probably PRC's or worked A.I./T.E.A. 243's/799's. I also want to run spray but would probably rather go with a plate wet system (125-150 shot).
With that set up would the SVO's be better or would I be better off with the 39LB injectors? They around the same price. Here are some links to what I am considering. Thanks everyone for your time.
http://www.ws6project.com/user_stor/...rs-30-lbs-hr-/
http://www.ws6project.com/user_stor/...rs-42-lbs-hr-/
I would get the bigger for round about the same price, in other words get the 39lbers. for 10 more bucks...
have you contacted FIC injectors? what are they willing to sell you for the same size?
They are a sponsor up here and have done a great job of providing information and support for this entire section.
http://www.corvetteinjectors.com/sho...?productid=324
Good info. Thank you. Would a 50 lb be too big tho? Most head cam guys are around the 42 lb mark. Nitrous I want to run wet from a plate right off the fuel rail. so that can be factored out of the equation. Not questioning your knowledge just wanting to make sure we are on the same page.
