Holley Dominator fuel pump for sale EFI or Carb
I have a brand new Holley Dominator 12-1400 pump for sale. Getting out of racing. Have many more LS parts for sale including an LS7 Crank and LS3 Ported heads. Here is some info on the pump. I'll take $275.00 for the pump and $80.00 for the matching carbureted regulator.
These Holley Dominator billet fuel pumps feature a patent-pending twin-pump design. It allows you to use one pump for cruising and both pumps when you activate the nitrous switch or start building boost. By staging the second pump, you eliminate the unnecessary recirculation and heating of extra fuel, which can lead to poor performance and hot fuel issues. They can also be wired for full-time duty to get the maximum performance and are proven with an 18 V compatibility at pressures of up to 80 psi. At only 5.1 lbs., they weigh half a pound less than other 1,000 hp pumps, and yet they have twice the features.
Features include:
* Billet aluminum construction with anodized finish
* -10 AN O-ring inlet/outlet for high flow and superior sealing
* Excellent for use with carburetor or EFI applications
* Compact for easy installation on frame rails or other tight spaces
* Proven durability beyond 3,000 hours in gasoline or diesel fuels
* Fully sealed, can be submersed if necessary
Features include:
