LS3 injector fitment question?
Ok I have an LS2 intake with injectors and fuel rail. The LS2 injectors are too small for my needs. I was wondering if LS3 injectors would be a direct replacement for the LS2's. Will they fit?
Here what you need
http://www.corvetteinjectors.com/sho...?productid=252
So the LS3's are shorter than the Ls2's? So i would need 8 height adapters? I am using a Gen 3 wiring harness as well so I probably also need a different connector? Thanks
