help me with fuel system
Old 01-14-2012, 05:10 PM
Fastdriver1992's Avatar
Default help me with fuel system
car is a 00 fbody already with a hotwire kit and racetronix pump. id like to build off what i have so its cheaper. car is 383 with d1sc ported trick flow 225, ls6 intake, brutespeed blower cam. should make 12 pounds and 16 when i up it. also have 80 pound injectors for it. should i add a kenne bell boost a pump and would the be sufficent? what else could i do? or would it be as simple as throing another 255 walbro in it
Old 01-15-2012, 07:49 PM
ZL1Killa's Avatar
i would either go dual walbros (255 pumps) or go with an external. Lonnies has a setup... Heintz Racing has a setup, I think also they make a 340 L/hr pump that you can put into the tank now
Old 01-17-2012, 11:32 PM
williamkeller23's Avatar
aeromotive makes the 340 lph
