Injector cleaner?? or just new fuel filter??
Old 01-16-2012, 10:15 AM
00Z28 ls1's Avatar
Default Injector cleaner?? or just new fuel filter??
my winter truck has a studder to it when it goes to take off and also gets horribal gas milage, its a 95 4x4 gmc 1500 (305) and was wondering if all the injector cleaners really work or if i should get buy a new fuel filter and put on it??
Old 01-16-2012, 10:57 AM
ZL1Killa's Avatar
how long has the fuel filter not been changed? this item is a relatively inexpensive...i would replace it and put in some seafoam.
Old 01-16-2012, 11:05 AM
firebirddude98's Avatar
^second that. filter's prolly like 10 bucks, and a jug of seafoam is like 8, and you only need about 1/3 to a half bottle for your silverado. Mine used to bog down before i changed the pump (pretty sure thats why it died, it had froze and i tried to run it) and it would die if i wasn't gassing it at about 2500, and i tried isoheet, and it would work for about every fill up. I put half a can of seafoam in it this winter, and it hasnt done it since, but then again, it hasn't been below freezing over 2 whole weeks this winter season
Old 01-17-2012, 01:51 PM
warriorcustoms's Avatar
Seafoam is a great product I saved a dude 1500 on his kawi ultra 150 cleaned up a stutter at mid throttle The injector flush works great too & clean that throttle body along with a filter
Old 01-17-2012, 04:49 PM
wildcamaro's Avatar
Sea foam is the way to go...new filter as well...do both be safe
Old 01-17-2012, 11:11 PM
it helped one of my buddy's silverado out to, it was really built up with carbon, so bad, that his cat's finally clogged up , so he cut em off
Quick Reply: Injector cleaner?? or just new fuel filter??
