trex cam, AI 243 Heads, ported fast 92mm will red top injectors?
Old 01-23-2012, 12:50 PM
camarodude87's Avatar
Default trex cam, AI 243 Heads, ported fast 92mm will red top injectors?
Hey guys just curious if ford injectors (red top) Im guessing 36lb injectors would work with this set up. I have a upgraded fuel pump, and was planning on running nitrous but yeah im missing some parts. anywho If I would run those ford injectors would I be able to run a 150 shot safely as well with just my heads cam and intake and around what cycle should I be around?
Old 01-24-2012, 04:22 AM
MJs1FastSS's Avatar
i have a similar set up but with trick flows and green tops 42#.... and with the 180 shot direct on a forged 370 i think i will be upgrading to a motron 60 so there is no issues and can go up if need be.
minium i would have on there are 42s
Quick Reply: trex cam, AI 243 Heads, ported fast 92mm will red top injectors?
