Can you run 2 255's off a boost a pump?
Old 01-28-2012, 10:03 PM
AutomagicLS1's Avatar
Default Can you run 2 255's off a boost a pump?
I'm going to need to buy a boost a pump for some new power on E85. I already have a triple 255 setup in the tank. 2 pumps come on via hobbs switch. Can you safely run 1 40 amp BAP on 2 255's?
Old 01-28-2012, 10:07 PM
SVTconfused's Avatar
we do it on lightnings all the time... hell most of the time its a boost-a-pump on the factory 155's
Old 01-28-2012, 10:08 PM
not saying that its safe on a camaro... I also know for a lightning it only takes about 20-22% more fuel to run e-85... but thats a different animal
Old 01-28-2012, 10:09 PM
I was just curious because it appears KB sells a dual pump boost a pump...so I wasn't sure if it was a must or it's just them trying to make a buck
Old 01-28-2012, 10:12 PM
me personally if im pumping that much fuel id rather have a big single pump... what happens if your WOT and one pump fails... you go lean but still keep running. At least with a big single you'll shutdown
Old 01-29-2012, 01:11 AM
Big Al's Avatar
If you're using more fuel than one 255 can pump you might be right. But if you're using Nitrous and your one pump dies, the next thing you hear will cost lots of money
Al 95 Z28 w/two Wabro 255's
Old 01-29-2012, 09:03 AM
Trust me... i know all about the the expensive noise... my background consists of proabally the most fickle motors to keep together... damn Svt junk
Old 01-29-2012, 09:23 AM
as much as I'd like to run a single pump i'm not sure it's worth the issues. I read on yellowbullet all the time A1000's will drop pressure over 50psi-other issues, magnafuel pumps will overheat 45 mins to an hour of running. Plus the Walbro pumps are proven to run 100K miles....how could you go wrong? The dual/triple 255 in tank setup is proven to work fantastic. Look how fast Vee8 and Mightymouse have gone with a triple 255 setup and have had no issues.
Quick Reply: Can you run 2 255's off a boost a pump?
