Dual walbros and -10 ok?
hey guys, i was planning on doing a triple pump setup but after reading mightymouse's sticky, duals walbros are going to supply all the fuel i'll need.
however, i already purchased my -10 line, fittings and Y block and opened them up, and tossed the packaging.
my question is, will the dual walbros feeding a -10 line rear to front into a Y, rails and then into a magnafuel reg be ok or will it drop pressure? hoping not to have to swap to a -8 setup and take a loss on this stuff but obviously going with what works is priority #1!
Thanks!
Edit........btw ET goals are 8.90's @ 3400RW in a turbo setup to give you an idea on fuel needed. second pump will be on a hobbs switch.
Thanks!
