stock return line size?
Old 02-03-2012, 10:16 AM
IKnowtheFuture's Avatar
Question stock return line size?
I am connecting the return from the fpr to braided -6 an hose. I have removed the stock return line from the t block under the car and blocked off the hole. I want to connect the an return line to the factory return line under the car.
It still has the fitting on the end. Better to get a compression to an fitting or a 14mm x 1.5 to female to an?
What size is the stock return line?
Old 02-04-2012, 02:18 PM
PRAY HRD's Avatar
if i'm understanding your question correctly, this is all you need if it's the same flare and all as it would be in the engine bay....http://www.jegs.com/i/JEGS-Performan...03100/10002/-1
Old 02-04-2012, 05:08 PM
Ollie8974's Avatar
This is the improved version of the Russell fitting.
With threaded locking ring.
Attached Thumbnails stock return line size?-assembly-step-1-russell-644120.jpg   stock return line size?-assembly-step-2-russell-644120.jpg   stock return line size?-assembly-step-3-russell-644120.jpg   stock return line size?-new-russell-644120.jpg
