Fueling Question
Fueling Question
I'm swapping an lq4 w/ l92 heads into my 1980 Firebird. I'm planning on using -6 an line and the Corvette fuel pressure regulator/filter. Do you see any problems with the regulator in the high 400's hp range?
I have the same setup with an LS6. It'll work fine... Check out the link below
Corvette filter regulator HP limitations
