What would you do? dd FI fuel pump recomondation
Im building a turbo 5.3 in my 95 ta. I dont know what to do for a fuel pump. I dont care how loud the pump is or how much work it will take to install. I have a sumped f-body tank and was going to run a mangnafuel mp4303 but am worried about heat. I want to drive this car...alot. Ive also heard a pump like that will have a low hour life. So could i run a in tank walbro and then have a boost refreneced inline magnafuel. I will be making 800 or so at the wheels. Thanks again guys
I believe with stock lines and a dual intake set-up you can support 700rwhp. After that you need bigger lines.
Might want to double check, but I'm pretty sure its in that ballpark.
The second pump will be boost referenced so you should have normal driveablity and sound levels until your under boost.
