LQ4 truck intake injector options
What do you guys suggest for injectors on an LQ4 with the truck intake? Right now it has these shorty or mini Delphi's in there. Need either a 60 or 80lb injectors. Can a put a set of the taller types in there? Seem to be a little cheaper.
Thanks
Vince
Thanks
Vince
I run the tall 60lbs injectors on my turbo rat with stock truck intake and fuel rails. I ordered the new connectors from summit and placed them on the truck harness. then used small washers to get correct spacing between fuel rail and intake.
your harness may have the correct ends already?
these are what i used:
http://www.summitracing.com/parts/MSD-2400/
I have a couple of options. I'm going to use my Holley HP system that was on my BBC prior. I can buy a LS - type injector harness and run the truck-style injectors, or try and reuse my Holley injector harness which has a Bosch style connector. Be nice to be able to use the current harness and a cheaper injector rather than the mini truck style's
