Where did you mount your external fuel pump?
Old 02-18-2012, 08:01 PM
konceptracin's Avatar
Default Where did you mount your external fuel pump?
Let's see some pictures of your external fuel pump setup
Thanks in advance!!!
Old 02-19-2012, 11:44 PM
No one has a ex pump?
Old 02-20-2012, 10:52 PM
Ford_Assassin's Avatar
I do and I am sure others do as well, but its not usually a photo op priority.
Mine is mounted along the frame just as the rail straightens back out.
Hope that helps.
Old 02-22-2012, 03:20 PM
Thanks for your help
Old 02-23-2012, 10:15 AM
gMAG's Avatar
Here you go...the pump is just behing the axle (in the 3rd photo). It can't be mounted higher than the gas tank. The Corvette filter/regulator is forward of the pump.
Hope these help, and sorry I don't have better pics.
The gas lines look quite close to the muffler, but actually are not.
Old 02-23-2012, 10:35 AM
Nice .... Do you have a stock tank?
Old 02-23-2012, 10:48 AM
gMAG's Avatar
Yes, it's a stock tank/no baffle. As long as you keep at least a third of a tank, the baffle is not an issue.
Also, the sock in the stock pump pickup (intank), combined with the Vette filter, is more than enough filtering.
Some folks add another external filter before the pump (in-between the tank & pump).
I was advised by John @ Speartech that the tank sock & Vette filter is enough. Any more filtering, and you'll put too much resistance on the pump.
Old 02-23-2012, 11:05 PM
Yeah I have. A nasty tank so I'm just looking to mount the pump
