LQ4 truck intake injector options
Old 02-20-2012, 04:58 PM
69-chvl's Avatar
Default LQ4 truck intake injector options
Tried the performance section but didnt get a whole lotta help, so I'll try here.
What do you guys suggest for injectors on an LQ4 with the truck intake? Right now it has these shorty or mini Delphi's in there. Need either a 60 or 80lb injectors. Can a put a set of the taller types in there? Seem to be a little cheaper.
I will be using a Holley ECU which uses a minitimer/EV1 connector - would like to reuse this harness if poss.
Thanks
Vince
Old 02-20-2012, 05:05 PM
Gee101's Avatar
I used the shorter injectors from fic with the truck intake. Also seen pics of guys running a spacer on the rails for the taller injectors.
Old 02-20-2012, 09:20 PM
69-chvl's Avatar
Have a link to the shorties?
Was thinking of running the tall Ls1 style injectors and spacing the rail up. There cheaper and I can reuse my injector harness.
Old 02-21-2012, 07:38 AM
MaxxMitchell's Avatar
That is what most do. Usually cheaper and easier to find them second hand as well.
Old 02-21-2012, 12:26 PM
69-chvl's Avatar
The only concern I have regarding the LS1 type injector is that the tip of the injector doesnt protrude as much as the truck injector. Just wondering if this would be an issue or not.
Quick Reply: LQ4 truck intake injector options
