Injector size for AI heads/cam setup?
So I have a 1999 Camaro and will be having the following done to the motor. It will have a BBK 85 mm throttle body and intake. I would like to know what injector size to get so I can send all my info to Frost for a mail order tune so I can drive it to the tuner on the correct injectors. I could also run on my current tune with stock injectors, not sure if it will hurt it if I dont get on it. Any ideas on injector size?
•Ai 219cc HCR Full CNC Porting
•Compression Ratio increased to 11.3:1
•Ai 230° / 238° 113° LSA .600"/.600" Hydraulic Roller Camshaft
•GM OEM .051" Head Gaskets
•Typically manages 440-460rwhp SAE corrected
I would say 38#'s or 41#'s for room to grow. I would like to mention a 255lph fuelpump might be something to start thinkin about, usaully the stock pump can handle about 450rwhp anything beyond that is pushing it.
i would grab a 255 pump (kit) and put it in, and put in 36lb injectors if you don't look at doing more. if you eventually end up doing more, the 36# will not be enough.
42# would give you growing room, and the 255 pump would provide plenty of fuel for them
https://ls1tech.com/forums/fueling-i...ump-chart.html
check out RCENG and injector sizing.
if you don't plan on getting a blower or turbo grab some 36# injectors and you will be able to easily make 480RWHP and 440RWTQ with ~60% duty cycle.
if you think you will be doing a lot more mods later, I would get 42# injectors
it really depends on the power you are either capable of making with the setup you have (or are about to build) or what you will be building.
