GTO FI fuel pump upgrade
Need advise on upgrading a 06 GTO fuel system for a forced induction application.
Would like to buy an in tank drop in unit if availiable. I can also consider doing a fuel pump swap if kits readily availiable. Dont know much about GTOs. trying to help a friend here.
Any advise wellcome.
Thanks for your time.
I have searched and was not able to find much information regarding the GTO fuel system upgrade. Lonnies performance has a double pumper kit but requires sending the unit in for modification.
So, I am thinking an inline pump might be a good option, dont know if the OEM pump would restrict the capacity of the inline pump though.
We also just released our DW65c fuel pump. It is a drop-in fitment 265LPH pump for the 04-06 GTO assemblies.
http://www.deatschwerks.com/dw65c-in-tank-fuel-pump
What kind of power are you looking to support?
Deatschwerks: I am looking for a fuel pump for my 06 GTO that will be supporting 500-650 rwhp. Is this the pump for me? I'm not sure what size injectors I will be running, although I would like to use the FAST 57 lb/hr LS2 plug and play injectors. But I'm not sure the injectors would support the power I'm aiming for: procharger D1SC at 6-8 lbs, Torquer v2 cam, Kooks headers, and FAST intake manifold, stock bottom end LS2 without meth injection. Thanks and sorry for hijacking OP.
here is probably another choice (not exactly sure what kinda buckets in your tank)
http://aeromotiveinc.com/2011/05/340-stealth/
