stock injectors on forged 370?
I'm gonna order a mail order tune for my car when i get it going its a forged 370 with a d1 but im gonna drive it around before i install the blower and stuff can i run it with the stock injectors ? Or will they not be enough? I dnt wanna buy some injectors when i already bought some 80s for when i install the blower.
you will be able to drive it, but I suggest not exceeding 4krpm @ WOT. if yuo want to drive it around just part throttle, the stockers will suffice. I do not recommend WOT.
[QUOTE=dschmittie1;16061691]Why not order your mail order tune set up for the 80# injectors and swap them in with the motor.
I didnt think that would work having that big of injector in there without the procharger.
[QUOTE=TermnEatr;16061938] well think about it, at idle with or without the supercharger the car is going to have the same airflow.
go ahead and when you put the motor in put the 80#ers in and get the tune for that. if the tuner knows this, and you tell them then they can be sure to take the time to tweak the injector tables , especially if you have injector data for your injectors and the car will idle and run fine with those 80# WITHOUT the supercharger. and with the supercharger, under WOT you will also be set
The whole plan is to install the motor will my 4l60e get a mail order tune from frost so I can get the car to Dallas tx . To ace transmission and get a 80e put in it. Then bring back throw procharger on and take it to my local tuner for a final SD tune. Ive never had a mail order tune whatsoever but I hear frost tuning is good.
