2 Fuel Tank Setup (Return line switcher)
Old 03-08-2012, 11:20 PM
v502's Avatar
Lightbulb 2 Fuel Tank Setup (Return line switcher)
Okay guys I need some help with figure this out.
I want a secondary tank for race gas and keep stock for pump. The feeds are pretty easy.
My only dilemma is return line, I want to return each type of fuel to tank.
I found 2 way solenoid valve but I know any restriction can build pressure in return line and will cause fuel-rail pressure problems.
So I contacted them about the flow and this is what I got. What do guys think? Could this work.
MPa = Bar
Here's the flow data:
Working pressure Liter/min
0.3MPa 32L/min
0.4MPa 36L/min
0.5MPa 38L/min
0.6MPa 42L/min
0.7MPa 48L/min
0.8MPa 56L/min
Old 03-09-2012, 01:04 PM
v502's Avatar
Bump !!
Quick Reply: 2 Fuel Tank Setup (Return line switcher)
