ls1 fuel rail weld on bung? - LS1TECH
Thread Tools Search this Thread
Old 03-15-2012, 12:17 AM   #1
Default ls1 fuel rail weld on bung?
I am tired of worrying about the reliability of my russell -6 AN to the ls1 fuel rail fitting that is known to fail. I would like to weld/braze a bung to the rail. Is it possible to do this to the factory rail? I know its thin material but i think i could tig it. Just wanted to check to see if this is a common mod.
birdman2447 is offline   Reply With Quote
Old 03-15-2012, 06:04 AM   #2
This is not done ever cause rail are cheap up grades, but it can be done by a very good tig welder. key word is very good as not to get a brittle weld that breaks with 60 psi of gas flowing though it while the engine is shaking all over the place
BigRich954RR is offline   Reply With Quote
Old 03-15-2012, 06:14 AM   #3
gi8e7oi825's Avatar
Well it's certainly not "not done ever". In fact, I somewhat followed Racetronix's idea here, Big cube FI Injector size?, but using only -6AN
gi8e7oi825 is offline   Reply With Quote
Old 03-15-2012, 08:07 AM   #4
Russell offers an improved version of the quick connect fitting.
Photo #1 old style push on.
Photos 2,3,4 new style with threaded locking ring.
ls1 fuel rail weld on bung?-russell-push-efi-fitting.jpg   ls1 fuel rail weld on bung?-rus-644110.jpg   ls1 fuel rail weld on bung?-side-view-russell-644120.jpg   ls1 fuel rail weld on bung?-new-russell-644120.jpg
Ollie8974 is offline   Reply With Quote
Old 03-15-2012, 09:33 AM   #5
BigRich954RR, that is exactly what i am worried about, I am very competent with tiging stuff that dosent matter, exhaust etc... I like the silver solder idea but dont know how much i trust that also.
Old 03-21-2012, 06:13 AM   #6
I am also wanting to braze on a fitting to the fuel rail I saw this aeroquip fitting (FBM2872) and I think it will work
reddfox is offline   Reply With Quote
Old 03-21-2012, 11:01 PM   #7
gi8e7oi825's Avatar
Well, it's definitely do-able. I bought two of Aeroquip's FBM2872 last July from Summit (don't pay more than $2.48 each!) and had them attached to my fuel rail by some highly recommended guy who tig welds for a living (or something), but a little differently than being discussed in this thread (on the rear of each rail). Before installing it, I'm going to pressure test it. That should be within the next few years lol
Old 04-02-2012, 11:24 PM   #8
bczee's Avatar
I have brazed a AN Bung on my fuel rail. Have had no issue and easy to do.. It is more secure than using the QD's.
Tip: don't brother with the high cost name brand fitting. If you have a Tubing/Hyd shop.. they sell the fitting and bung in bulk. I picked up 3 3/8" pipe to AN -6 adapter for less than $5.00, These are cheaper than a regular Weld on Bung. Cut the Pipe end off, drill the adapter about 1/4" deep for the Tubing to fit in and then just braze/Tig/weld it on..
BC
bczee is offline   Reply With Quote
Old 05-07-2012, 04:17 PM   #9
RaceDriver's Avatar
Do you have the part number for the new style?
RaceDriver is offline   Reply With Quote
Old 05-07-2012, 04:33 PM   #10
MM98's Avatar
Quote:
644120 for blue & 644123 for black.
MM98 is offline   Reply With Quote
Old 05-07-2012, 04:54 PM   #11
RaceDriver's Avatar
Quote:
Awesome, thanks. Going to replace mine, I have the old style.
Related Topics
Thread Thread Starter Forum Replies Last Post
Turbo drain timing cover slolt1 Parts Classifieds 19 02-10-2016 04:13 PM
Welding bungs houston area 99WS6_ Texas Members 1 07-06-2014 11:15 PM
LS3 Fuel Rails mklaus1 Generation IV Internal Engine 2 09-11-2013 09:56 PM
Anyone ever weld on an LS1 stock fuel rail? WS6HUMMER Fueling & Injection 2 04-13-2009 11:36 AM
upgraded fuel rails and fuel rail covers awd-rwd racer Appearance & Detailing 3 01-19-2009 11:16 PM
Tags
4an, adapter, bung, feul, fitting, fittings, fuel, ls, ls1, npt, rail, rails, weld, welded, welding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
