Help with AN sizing.
Old 07-31-2017, 03:44 PM
jlee29's Avatar
Default Help with AN sizing.
Hey guys I'm putting a new fuel setup in my car and I need help with the sizing. I want to run
10-AN feed
8-AN return
Twin Walbro 450's in tank
My question is for the feed line do I need all of my hoses and components from the pumps to the rail to be 10-AN including the FPR? I ask bc I need to buy a FPR and a lot of them are 6 or 8-AN. Would it be redundant to run a 6 or 8-AN FPR and line to the rail (3' of line)?
I feel like the obvious answer is yes 10-AN all of the way, but I already have some 6 AN lines and was curious if I could use them.
Thanks
Old 08-01-2017, 12:06 AM
Received 3,021 Likes on 2,352 Posts
Depends on the actual need for fuel your engine has. How much HP are you pulling? If it's the engine mentioned at the bottom of your post, 8-AN would likely get the job done. BUT, if you have done a LOT more to the engine, then 10- is your number.
Old 08-01-2017, 06:57 AM
HoodRatHotRod's Avatar
It depends on how much horsepower you need to support, but ideally if you're plumbing it primarily with -10 I would want the whole feed side to be -10 or larger. -8 is typically good up to about 750hp on gas, though.
Old 08-01-2017, 08:41 AM
Restricted User
JoeNova's Avatar
-10 is what they use to feed methanol to 4000 HP pro mods.
-6 line is more than enough for any N/A LS setup.
Old 08-01-2017, 12:02 PM
jlee29's Avatar
The car is a 6.2L with a D1SC so as it is it should be in the upper 600-700rwhp on E-85, so that's the reasoning behind running a massive feed line.
I think the best option is to get a 10 AN FPR and run 10 AN right up to the rail. I just feel like I rarely see a large 10 AN line between the FPR and the rail even on higher hp cars.
Old 08-01-2017, 12:12 PM
Restricted User
JoeNova's Avatar
The highest I've seen out of -6 on gasoline is 1528 HP.
Carbs need large fuel lines because of less line pressure, so going by any rule of thumb that a carb guy has tried to give you is completely irrelevant.
You see lots of people running -10 because they are in the same boat you are and don't know what to run, so they just run a huge fuel line.
Old 08-01-2017, 02:03 PM
You've seen a car make 1500hp with -6 fuel lines?
Old 08-01-2017, 02:23 PM
Restricted User
JoeNova's Avatar
BMW I6 on an engine dyno, yes.
Its amazing what enough fuel pressure will do.
Old 08-01-2017, 02:31 PM
RedRocketZ28's Avatar
I run -8 feed and -6 return. More than enough for me on E85 and I make more power than what you're wanting to make.
Old 08-01-2017, 11:22 PM
jlee29's Avatar
Okay cool. Thanks everyone
Old 08-10-2017, 08:41 AM
prokaw875's Avatar
Hey man, so I was in a similar situation but with a big Weldon external pump. I have 10 feed and 8 return. Reason I went this size is because I got a weldon T2040 regulator which has 10AN feeds and 8AN Return. I don't like the idea of bottlenecks anywhere. I believe if you don't want to spend $250 or $300 on a weldon A2040 or Teflon (methanol safe) T2040 then aeromotive I THINK has a 10/8 sized regulator. If not then just get a 8an/6an regulator and get adapter fittings 8an orb to 10AN male and 6an orb to 8AN male. Whatever you do I would try to stick to 10AN feed and 8AN return that way you will never have limitations
Old 08-10-2017, 07:04 PM
jlee29's Avatar
Thank you! I've decided to run 10 all of the way. I just got a 10 AN FPR so I'm all set. Like you said I don't want any limitations in the future.
Old 08-10-2017, 11:11 PM
Dian's Avatar
is that a returnless setup?
Quick Reply: Help with AN sizing.
