How much can I spray my setup with the stock fuel pump?
Just put a tr224 comp cam in my TA, it dynoed 361 hp/373tq through my 3200 stall. I've got 42 lb injectors but the stock fuel pump.
How much spray (if any) could I spray on top of that with the stock fuel pump?
If you are spraying nitrous with a cammed car then it would be wise to get a pump. The rest depends on if you are spraying wet or dry for your nitrous set-up. Read stickies for explanation.
You should have enough fuel to make close to 500whp. So I'd start at 75 shot. But fuel pump would be a good idea. Trap doors easy to make and a aeromotive 340 will give you more than enough fuel
