Hot wire kit not working?
Old 04-01-2012, 07:27 PM
SWEET98SS's Avatar
Default Hot wire kit not working?
So I bought a hot wire kit off a sponsor. The kit is pretty self explanatory, one wire to the alternator, then the connector that goes between the pump and factory connector.
So I got my car all put together and the fuel pump doesnt turn on, connected the factory connector to the pump, works fine. I am assuming the relay is bad.
Anyone ever have this problem?
Old 04-02-2012, 02:11 AM
EngineBuilder59's Avatar
Stupid question...
Why would you want a hot wire kit?
Could well be a relay problem.
Old 04-02-2012, 05:36 AM
SWEET98SS's Avatar
The factory wiring is too small for the amperage of the racetronix pump. It will melt the wire and connector
Old 04-03-2012, 01:23 PM
TransamGCS's Avatar
you need to check your grounds off the hot wire kit make sure the grounds are making a good metal to metal contact on the frame.
