Injector sizing for procharged 383
Old 04-03-2012, 01:47 PM
Valkyn's Avatar
Default Injector sizing for procharged 383
Trying to start putting some parts together for my procharged 383 LT1 build. My goal for the build is 800 RWHP, im still debating between F1A/C/R blowers but I would like to have some room to grow over 800 if I want.
Using the calculator in the sticky I come up with that I need roughly 80 lb injectors to run at 80% duty cycle at 58 psi fuel pressure.
So my question is, what fuel pressure do you want to run on a supercharged setup like I'm planning? Assuming it is, would low imp 120lb injectors work alright for my setup or would they be overkill? And are there any brands I should look for or stay away from?
Old 04-03-2012, 05:39 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
120's are overkill.
Give me a call & I'll be glad to help you out.
Old 04-03-2012, 09:08 PM
ZL1Killa's Avatar
going to guess 90 ~ 96# injectors
Old 04-03-2012, 10:25 PM
F0x Slaughter's Avatar
For 800bhp at .60 BSFC with 8 injectors at 58 psi and 80% cycle you would need ~65lbs/hr.
Why do you want to run 4 bar?
Old 04-04-2012, 08:07 AM
ls2 goat's Avatar
He's wanting 800+ RWHP, not crank HP. 65's will not support his fueling needs.
Old 04-04-2012, 09:27 AM
Valkyn's Avatar
What fuel pressure do guys typically run in forced induction setups?
Old 04-04-2012, 08:46 PM
81lbs hr for 1000bhp. At 58psi.
Old 04-04-2012, 08:54 PM
ZL1Killa's Avatar
our ls1 and etc. from GM are all 4 bar, 58psi. **most fuel injectors are rated at 43.5psi.
all of those above mentioned calculations for sizing injectors are based on engine HP numbers, not rear wheel numbers as stated further in this thread. A good injector for this setup would be a 90# or 96#, and would have head room. As 81 LBs at 1,000bhp equated to what duty cycle? 80%? 85%?
Old 04-04-2012, 09:47 PM
80%
At a BSFC of .60 for a supercharger.
Old 04-04-2012, 10:22 PM
ZL1Killa's Avatar
80%
ok, thats really not leaving much headroom, so a 90# would give some extra head room in case it made more power
Old 04-05-2012, 09:32 AM
Valkyn's Avatar
Since I'm going to be redoing my entire fuel system should I run the 43.5 psi fuel pressure or stick with the stock 58?
Old 04-06-2012, 01:39 PM
I don't own a LSx so I can't tell you haha. I know jack about their fuel needs.
Old 04-06-2012, 08:12 PM
ZL1Killa's Avatar
sticking with the 58 gives you more headroom as injectors are rated at 43.5. I would stick with 58
Old 04-06-2012, 11:41 PM
The injector size I listed was for 58 psi. Not 43.5 psi. So at 43.5psi you would need and even bigger injector.
Old 04-07-2012, 08:00 AM
LS1TECH Sponsor
You should run the lower 3 bar pressure as it will be easier to maintain boost referenced pressure settings. You should design around the lower pressure whenever possible.
