E85 tuning questions
Old 04-06-2012, 12:22 PM
Taubr Unit's Avatar
Default E85 tuning questions
Im having my truck tuned next weekend and wondering what other tweaks I can/should do before hand. I'm gonna have it tuned on e85 so I'm wondering if a better plug runs better with e85 or not. Everyone with ls1's use ngk tr-55's but does e85 like a hotter or colder plug or doesn't matter? My truck is a 2011 silvo with a 5.3 with CAI, modded air box and catback with a xr-1 muffler.
Old 04-06-2012, 04:21 PM
RAACCR's Avatar
NGK 3177 BR6EF Non-Projected Tip
Gap it so the ground strap is square with the electrode.
(Might be a little tighter than you're used to, but the plugs work best when the gap is square.)
Old 04-06-2012, 04:38 PM
Taubr Unit's Avatar
Now how will that plug work if and when I need to switch back to 87 oct gas once in a blue moon?
Old 04-06-2012, 06:50 PM
BuffJoeyD's Avatar
Be interested in how well the stock fuel pump holds up to long term E85- Is your truck a flex-fueler already?. People go ahead and give me crap, Run Champion copper plugs gap at .45+ Hope your tuner is good.
Old 04-06-2012, 07:08 PM
Taubr Unit's Avatar
Ya it's a 2011 flex fuel, has 36 lb injectors from factory to work with it. I may just stick with the stock plugs though if there's no hard evidence for the extra work
Old 04-07-2012, 08:47 AM
LS1TECH Sponsor
Lonnies Performance's Avatar
The type of plug is less important than the proper heat range.
Even though alcohol burns cooler, leading one to believe it needs a hotter plug, it burns cleaner, leading to less fouling/carbon buildup problems.
Since you are normally aspirated, your current plug will likely be OK.
Old 04-07-2012, 09:11 AM
Taubr Unit's Avatar
Thanks Lonnie, pretty much what I was thinking. Not gonna spend the time or money on a different plug. I would assume gm put a plug in anyways to work with both gas and e85..... I hope at least, lol
Old 04-11-2012, 04:52 PM
Taubr Unit's Avatar
some food for thought...
Old 04-11-2012, 09:29 PM
Gregory's Avatar
The below picture of my LS2-402 TR55 plugs on E85 after 3,000+ street miles. Just an accurate tune.
Quick Reply: E85 tuning questions
