fic high imp 120s vs id1000s
Old 04-10-2012, 07:46 AM
TermnEatr's Avatar
Default fic high imp 120s vs id1000s
Looking to switch to e85 on my setup have a few ?s which one flows more and is better all around? Are the ids as dropin ready as the fics?
Old 04-10-2012, 12:24 PM
ZL1Killa's Avatar
same bosch injectors but different model for different flow.they are both flow tested and dynamically flow benched... same.
i'm getting ready to test the ID725 versus FIC725, it will take me likely two weeks with work the way it is right now.
price wise, there is quite a difference. From what I have learned I would keep or grab the FIC120s.
120LB/hr @ 43.5psi = ~138LB/hr injector at 58psi
ID1000 are 1,000cc equates to 95.15LB/hr @ 43.5psi
or 109.4LB/hr at 58psi
Old 04-10-2012, 03:34 PM
Alpha's Avatar
They both work very well.
Old 04-10-2012, 04:54 PM
TermnEatr's Avatar
All I needed thanks!
Quick Reply: fic high imp 120s vs id1000s
