Do you need to change O rings?
Old 04-24-2012, 11:09 AM
needtransam's Avatar
Default Do you need to change O rings?
Ok so I took out my fuel rail to inspect the injectors and clean/test them, I just reused the same o-rings, wondering if I did bad and I should have bought new ones?
Old 04-24-2012, 03:25 PM
Old Geezer's Avatar
On the injectors I clean, I often find that the used rings fit loosely in the bench adapters, and leak.. So often, that I just change them B4 bothering to try a test...
You may get away, may not...Murphy live around your place?? He does here!
Old 04-24-2012, 04:11 PM
i see were can i buy new o rings
Quick Reply: Do you need to change O rings?
