Dual intank walbros in stock plastic tank....is 70 PSI too high??
Hey guys. I'm getting 70 PSI at idle for fuel pressure with a dual walbro setup. I have the stock plastic tank and bucket assembly thats been modified for twin walbros. -8 AN feed line to the stock F body rail, and a "T" in the line that goes back to the tank and through the stock in-tank regulator. Also 80 lbs injectors. Anyone see any problems when trying to tune this, and should I be concerned about it?
The weird thing is that with stock injectors, it seemed to be where it should, at around 58-60 PSI. Now with the 80's, I'm suddenly at 70 psi.
And yes, both pumps are on all the time. My tuner said I should be ok without a hobbs type of switch setup.
Problem is that I already did the whole fuel system using 1/2" aluminum line and all AN fittings with braided hose at the ends. I REALLY don't want to rip it apart and essentially start from scratch. If it runs a little rich at idle, I don't really care. As long as it's not going to cause a problem down the road. I would much rather run a hobbs switch than redo my entire fuel system.
What I'm curious about at this point is if 70 PSI at idle will actually hurt anything besides making it run a bit rich at lower RPM?? Some gas engines run 70-80 PSI fuel pressure from the factory and are fine.
Yes, it's the car in my sig. And there are different definitions to "right" lol. Lonnies uses the stock in-tank reg with dual walbros and a hobbs switch and they have had some pretty big HP cars use that setup. Plus, I can always change it and improve down the road, but I JUST got this car streetworthy and am not ripping it apart so soon to change the entire setup. I just need to get it going for now so I can drive the damn thing.
The stock regulator obviously isn't up to the task. It's supposed to maintain it at 58lbs. If you had an aftermarket adjustable regulator, you could set your base pressure is in a range from something like 30-60lbs. Which means as a boosted engine, if it's a 1:1 regulator, for every 1psi of boost, the fuel pressure will also raise 1psi. Then you would adjust your injector flow rate table to one pressure straight across the board.
You can have big power without boost. That's what I'm getting at. If you were n/a, then it wouldn't be an issue. But having a boosted setup, the boost reference is the way to go.
i didnt notice you had a turbo setup.. i had this regulator on my talon and it worked great if you search the net you could find a better price and they make a -10an sized one also
http://www.ebay.com/itm/IE-Fuelab-FP...#ht_1125wt_952
