Can the stock LS1 fuel pump be changed without the entire assembly?
I don't wanna spend $300 for an assembly if I can just pull the pump without trouble. I know the Haynes manual says the pump itself isn't serviceable alone and that the entire assembly has to be changed out.
What does the fuel pros say??
If you are running stock, you should just replace with the full OE fuel module assembly, not a high performance fuel pump, check Amazon you can find some good deals versus the brick and mortar retailers
Not so fast, only Racetronix supplies a proper kit for 98 or 99-2002 LS1 Camaro's or certain year Corvettes....Walbro/DW/Aeromotive do not have the proper venturi function or mounting components.
http://www.gonicd.com/intankinstall/...mpinstall.html
