Introducing our new 127lb Bosch racing injectors
Old 05-17-2012, 09:18 AM
FICINJECTORS's Avatar
Default Introducing our new 127lb Bosch racing injectors
After alot of testing and many happy customers we are officially introducing our 127lb @4bar LS drop in. We have 5 different configurations. The injector will support all fuels including Q16. These are from Bosch Racing. We flow match them Dynamically at all pulse widths. We have the correct tune data in Efi live and Hp Tuners. Dyno tested and tuned by Vengeance PCM in Ga. These have a 100% money back guarantee if you are not happy with them! No questions. Notice in the picture the extended tip which is ideal for the LS head especially the cathedral port design. Call to order..
Attached Thumbnails Introducing our new 127lb Bosch racing injectors-127line.jpg
Old 05-17-2012, 09:57 AM
MIGHTYMOUSE's Avatar
I switched to these from 96# low z and am pleased thus far with the results.
Below is a 12.5# boost run (9.6 at 145) where you see the injector is at about 40% duty.
This is with an auxiliary methanol shot and the numbers crunch to 900hp. Fuel pressure is 3 bar plus 1:1 for boost.
Injector delay is set around 1.3ms in BS3 currently along with a size of 1156cc.
Old 05-17-2012, 02:34 PM
LS1TECH Sponsor
Vengeance Racing's Avatar
Guys these injectors were just put in our 1060RWHP 2010 Camaro and they run great.
These injectors are next leap forward for the big boys.
No questions best injector I have seen in awhile that has come out.
Old 05-18-2012, 09:30 AM
dasorcha21's Avatar
Great new product you guys have brought to the market! thumbs!
Old 05-18-2012, 09:57 PM
adrynalinjunkie's Avatar
How much rwhp could I make with these on E85 With a S88 Turbo through a TH 400 ?
Old 05-18-2012, 10:20 PM
Running duty cycle to 90 you should be ok at 1200 chp.
Old 05-18-2012, 10:44 PM
I will call you soon.
Old 06-13-2012, 10:23 AM
SRTKLLR's Avatar
I currently have your 95lb(108@ 4 bar) and was wondering if these new injectors were better. Would it be worth it to switch? Also, I could not find them on your web page. Can you post a link.
BTW, They would be for a LS3 2010 Camaro.
Old 06-13-2012, 07:35 PM
They are better only if the 95 are maxed out. Both excellent injectors. These are from Bosch racing complete with tune data
Here's the link
http://fuelinjectorconnection.com/sh...p?productid=11
Old 06-19-2012, 09:54 AM
ls2 goat's Avatar
I've been nothing but impressed with the set you hooked me up with. Can't wait to see how the handle the race tune.
Old 06-20-2012, 09:20 PM
mchdg86's Avatar
What is the reason behind the extended tip version? Are there any benefits over the normal ones?
Old 06-21-2012, 07:50 AM
i believe the extended tip is so you can run a lower spacer to get the injector up to the length of a ls1 style injector while still having the nozzle tip not up inside the spacer, screwing up the spray
Old 07-19-2012, 09:54 AM
Orr89rocz's Avatar
IF these are good to 1200 on E85, what about 93 oct or C16 race gas? 1500? Considering using them at 3 bar + 20psi boost max, so just abit over 4bar fuel pressure at WOT.
Old 07-19-2012, 10:14 AM
pm sent
Old 07-22-2012, 04:53 PM
bad6as's Avatar
Fic the 95s 3bar 103s 4bar using a magna fuel 4303 pump and -10an feed. What chp can be reached?
Old 07-22-2012, 06:46 PM
What fuel?
Old 07-22-2012, 07:02 PM
bad6as's Avatar
Gas and also e85
Old 07-23-2012, 05:09 AM
mowton's Avatar
We are using these injectors in a 1000 rwhp LS3 Corvette project. Have these injectors been flow tested in Delta pressure conditions during boost (200kpa to 400kpa)? The data we got only was for 0-80 kpa so I inserted that data into Marcins injector calculator worksheet to get the boosted values.
Thanks
Ed M
Old 07-23-2012, 01:24 PM
Gas and also e85
on gasoline you can hit 1200chp on e85 about 850chp.. this is at 80% ds.. you can run these injectors higher ds if you want.. how much hp are you trying to make
Old 07-24-2012, 08:13 PM
LS1Tech Sponsor
Slowhawk's Avatar
It's actually the other way around. The extended tip ends up in the intake. Closer to the back of the valve.
Got a set going in my car.
Quick Reply: Introducing our new 127lb Bosch racing injectors
