Line and fitting size question? - LS1TECH
Thread Tools Search this Thread
Old 06-01-2012, 12:47 PM   #1
charlie97z28's Avatar
Default Line and fitting size question?
Jus picked up a fast setup with aeromotive rails what size fitting do I need to run braided line from the factory filter on and what size line should I run -8 or-6
charlie97z28 is offline   Reply With Quote
Old 06-01-2012, 03:04 PM   #2
Old Geezer's Avatar
A -6 should do the job, unless you are planning to feed big HP.....
Summit has the adapters w/ the screw in retainers for both the inlet, outlet, and the return lines.
5/16 return is 644113 Black Blue is 644110
3/8 filter in is 644123 Black Blue is 644120
Filter out is 640940 Plated
We use a combo of colors to ID the return vs the inlet....
Old Geezer is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
