Will these injectors work for my setup?
Old 06-16-2012, 07:38 AM
DarkHorse's Avatar
Default Will these injectors work for my setup?
Guys, i'm needing help figuring out if these injectors will work for my combo, as in will they physically fit and be enough to handle what I want, etc...
My combo:
01 LQ4 cam/springs (unsure yet)
Typhoon intake/rails (smoking deal)
S475 T4 83mm 1.25a/r
LS1 f-body harness
AEM 10 channel Peak and Hold injector driver box
http://www.summitracing.com/parts/AVM-30-2710/
The injectors i'm looking at are FAST #308308
http://www.jegs.com/i/FAST/244/30830...ductId=1524861
FAST #244-308308
Fuel Injectors 83 lbs./hr.
Low Impedance
12 V Saturated Circuit Driver
Universal
Set of 8
I will be running pump gas only, 16lbs max
Will they work for this setup?
Thanks!
Old 06-16-2012, 11:51 AM
bwkmaro's Avatar
your only gunna run 16psi of fuel pressure? because most fuel injectors are rated at 60psi or 4 bar so those 80lbs injectors go to about 20 pounders. i could be wrong about these injectors tho
Old 06-16-2012, 03:15 PM
wkdivr's Avatar
I would be that's 16psi boost.
Old 06-16-2012, 03:23 PM
bwkmaro's Avatar
haha my bad yea you should be fine. wasnt useing my head
Old 06-16-2012, 04:29 PM
Old Geezer's Avatar
Question Too many ....
hits on the bong??????????
Old 06-16-2012, 05:47 PM
DarkHorse's Avatar
Lol yes 16lbs boost.
Turns out they were siemans deka fi11405 injectors...I bought them. Hope it works out
Old 06-19-2012, 09:42 PM
ZL1Killa's Avatar
why do you need those injectors and the driver box? why not buy some high impedance injectors, no need for an injector driver box... I don't understand your needing or wanting the low impedance ones.
well i see you bought them, hope all works well.
you could have bought some 90 or 100 LB high impedance injectors from FIC and been on your way without all that extra crap
Old 06-20-2012, 09:10 AM
DarkHorse's Avatar
My harness already had the box wired in and the injectors cost 150 bucks new in box from a buddy so......
Old 06-20-2012, 11:51 AM
ZL1Killa's Avatar
thats fine, they should work. I just wanted to know
