Best (quick?) connect fuel fitting, 3/8 -6
Getting the fitting to hook my billet rails (-6) to my stock fuel line (2001 Z28 3/8) and reading a lot of the fitting have problems with popping off and leaking over the years. Russell, aeromotive, ect... Some claim the fixed it, but people still have problems with them. Sounds like it the easy no tools plastic clip ones. Dose anyone make a better fitting that clips on better, I have no problem using the fuel line disconnect tool. But don't see and the OEM style connector that is -6 fitting
If you don't mind destoying the stock line.
You can also solder or weld and AN fitting to the steel line.
You could use a repair fitting and weld to that too if it's out of sight.
Aeroquip makes an adapter line called versa flare that will go from tube to AN. ($5-$7)
It looks like the new Russell fittng has fixed the issue also.
