what fuel cell, pump/s, injectors for turbo LS on E85 - LS1TECH
Thread Tools Search this Thread
Old 07-01-2012, 12:40 PM   #1
Default what fuel cell, pump/s, injectors for turbo LS on E85
Looking at doing a large turbo 5.3 on E85 in a first gen camaro, and would like to see 700+. The car will be a street car seeing a lot of action in mexico and the track. It will be tubbed and Im not planning on spending $1200 on a stock replacement tank, so Im wondering what fuel cell I should look into as well as how much pump will I need, as well as injectors. I would like room to grow so 1000hp setup would be ideal.
stevo8 is offline   Reply With Quote
Old 07-02-2012, 01:32 AM   #2
Doin the same to a 65 stang with a 6.0l and an 80mm
baggins is offline   Reply With Quote
Old 07-04-2012, 01:57 PM   #3
160lb injectors and a pump to support them
sprayedenali is offline   Reply With Quote
Old 07-04-2012, 08:19 PM   #4
I have pretty much the same question but with a TVS2300 on a forged 6L. 18PSI.
Already have 110lb injectors but that might not be enough.
Koondog is offline   Reply With Quote
Old 07-04-2012, 09:54 PM   #5
FIC or ID 160-220's
weldon pump ( with controller) or magnafuel or aeromotive eliminator (with controller) or Fuel Lab pump.
supporting lines etc, -10 feed's and -8 return
typhoon1015 is offline   Reply With Quote
Old 07-05-2012, 08:53 AM   #6
Heres my setup for right around 700rw on E85.
Jegs 15 gallon fuel cell
(2) external gravity fed walbros, each with a 40 micron Jegs prefilter and a -8 feed off the cell sump then y'd into a -8
Magnafuel filter
stock ls1 rails
Aeromotive 13101 before the rail
-6 return
58 base
95lb Delphi at approx 90% duty
It did 824 flywheel on 16psi, now at 19psi in the car, so Im estimating easy 700rw.
If your looking for 1000rw eventually on E85, Id suggest FIC1600's and a Magnafuel 4303 with -10 feed/return, a -12 feed to the pump, and two -8 vents.
LS1NOVA is offline   Reply With Quote
Old 07-10-2012, 03:06 PM   #7
AlterEgo's Avatar
Magnafuel filter
stock ls1 rails
-6 return
58 base
You dont think the aeromotive A1000 pump will work?? Thats what I have would like high numbers with E85.
AlterEgo is offline   Reply With Quote
Old 08-31-2012, 01:29 AM   #8
Anyone used the new Holley dominator pump?
Related Topics
Thread Thread Starter Forum Replies Last Post
800hp turbo 6.0 e85 Chw Fueling & Injection 11 12-30-2016 09:53 PM
Injector/Pump setup for turbo e85. Maxed out my 95lbers. willizm Fueling & Injection 1 03-19-2013 09:05 PM
402LS,E85,91mm turbo what fuel setup to run 70ls1chevelle Forced Induction 6 02-11-2013 02:00 PM
5.3L t72 turbo fuel pump and injectors G-Body Fueling & Injection 1 08-26-2011 01:51 PM
Getting fuel to the turbo LT1 94dragbird Forced Induction 11 03-14-2009 12:16 PM
Tags
95, boosted, car, cell, comaro, e85, fuel, ls, ls1, pump, pumps, stock, street, timing, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
